SATA AHCI drivers problem? (AMD system)
ZeroCool22
Motherboard:
ASUS ROG STRIX B550-F GAMING (WIFI)
Processor:
RYZEN 9 5900X
Memory (part number):
CORSAIR 2x16 3000 Mhz CMW32GX4M2C3000C15
Graphics Card #1:
MSI GTX 1080TI 11GB GAMING X
CPU Cooler:
COOLER MASTER MASTERAIR MA610P RGB
Power Supply:
AEROCOOL KCAS 700WFULL RANGE
OS:
Windows 10 x64 (20H2)
I should have the same amount of SATA drivers than HDD/SSD drives i have?
I have 5 Disks installed in my system (3 SSD and 2 HDD) but i only have 1 SATA AHCI driver...
Also it says it's from 2006...
I feel my system a little sluggish in daily tasks jobs, could it be a problem of the SATA drivers?
MoKiChU
Level 40
To understand better, you should know that :
SATA AHCI : The controller is in your motherboard, and it drives all your SATA AHCI SSDs/SSHDs/HDDs connected on it (so there will be 1 single SATA AHCI Controller device for all SATA AHCI SSDs/SSHDs/HDDs).
PCIe NVMe : The controller is in your NVMe SSDs (so there will be as many NVMe Controller devices as there are NVMe SSDs).
So to summarize, yes it's normal.
MoKiChU wrote:
