Problems & Solutions
jetkid
Hi everyone
These days I have had several problems with Armory Crate on Win 11 Pro.
HW with synchronizable LED:
-Mobo X570-E
-VGA Tuf 3080
-Corsair H100i Cappellix
-Corsair Case Aux FAN
-Trident Z NEO
1. The plugin for the RAM trident Z in the AURA synchronization section disappeared.
-> solved
Procedure: deactivate Windows FAST boot, restart, reopen AURA Synch, select the RAM together with the other necessary devices and set any effect.
2. Corsair iCue no longer finds ASUS mobo / vga (with plugin option enabled)
-> solved
Procedure: as for point 1, deactivate Windows FAST boot, restart, reopen AURA Synch, select the necessary devices and set any effect.
3. When Corsair iCUE controls ASUS mobo / vga, the LEDs on the RAM modules turn off completely
-> solved
Procedure: close the iCUE program, download sysinternals process explorer, put the Corsair.Service process on hold, start Armoury Crate, Open AURA Synch section, select the RAM together with the necessary devices and reset any effect, close Armoury Crate, resume the Corsair.Service process, reopen iCUE Program.
4. Unable to update Game SDK (error 16).
not solved, i had to reinstall windows.
ASUS support has requested the opening of a ticket (several users complain about the problem).
Note: in my case this particular problem occurred after reinstalling Armoury Crate.
Hope all of this can be helpful for someone with the same problems.
Bye!
Nate152
Hi jetkid
The GameSDK Service error 16 is a known issue, they are working on a fix.
Keep an eye out for future updates.
