Crosshair VII HERO and COOLER MASTER Masterliquid Lite 240
max_mcee
Hi.
I installed COOLER MASTER Masterliquid Lite 240. The device is working properly, the CPU temperature is right.
When I start my computer, I see a message like this:
93455
Any ideas? Thank you.
9 REPLIES 9
RedSector73
Level 12
In the BIOS, did you change it to AIO ?
Also, do you have the plug for the AIO plugged into CPU_FAN header
@RedSector73
Please help me. How can I change it in bios?
RedSector73
Level 12
Go into Advanced
Monitor -> QFan Configuration
AIO Pump Control Enabled.
off memory, ymmv.
RedSector73 wrote:
Go into Advanced
off memory, ymmv.
I turned it on, however it still gets the same error
93462
RedSector73
Level 12
Do you have it plugged in correctly?
The pump AIO_Pump Header (far right) and the fans should go to the CPU_Fan header (middle) and the other (left) CPU_Fan_Option.
I connected the pump to the AIO_PUMP connector, and the fans to the CHA_FAN1 connector.
93466
93467
93468
RedSector73
Level 12
I've told you how to fix it.
yes, thank you very much for your help
