03-18-2020
05:26 AM
- last edited on
03-05-2024
08:14 PM
by
ROGBot
03-19-2020 12:21 AM
rianquinn wrote:
Ok, so I just got this $400 wireless router thinking it would be a upgrade, only to find out that its slower than my Linksys AC router. This is my setup:
- Comcast with 200 down (i usually see 250)
- Line coming in is connected to a modem
- Modem is connected to my Linksys. Wireless on the Linksys is disabled, I simply use it as a router with NAT, DHCP, etc...
- AX11000 is connected to the Linksys (via the ethernet ports, not the WAN or 2.5 ports)
- The AX11000 is setup in AP mode, so it only provide wireless access.
As for device connections, my main system (I run the Zenith II Extreme Alpha with an AMD 3990X) is connected to the Linksys directly (i.e. it is not connected to the AX11000) and I see 250 down when I do a speed test. My XBox and Apple TV are connected to the AX11000 directly, as well as all of my wireless devices. When I do a speed test from both wired and wireless devices, I see 60 down at best (sometimes it is as low as 20). I also see a lot of signal degridation. For example, my brand new laptop, sitting 2 feet from the router sometimes only sees 80% signal strength, and my iPhone cannot get a good signal downstairs which was never a problem with the Linksys when it was providing wireless.
I have the latest firmware, and I reset all of the factory settings. I have no idea what to do to get this thing working. I don't think it has anything to do with the wireless radio settings as I see this issue on wired as well.
Any ideas?
Do I just return this thing and never get an ASUS router again?
04-01-2020 12:29 PM
04-02-2020 07:19 AM
03-26-2020 02:42 PM
Any ideas?
