09-10-2018
09:52 PM
- last edited on
03-06-2024
07:20 PM
by
ROGBot
09-13-2018 01:21 PM
Rythmicone wrote:
While gaming under a normal load, the 230w charger supplied with the GL702VS (gtx 1070, Core i7 and 120hz G-sync monitor) gets hot. It will start to throttle. When there is a power shortage, you get frame stutter, and crackling in any bluetooth headsets, not to mention wear on the system. The battery has to be called upon the help out under load, and hence drains it during gaming while plugged in. There is simply not enough power supplied.
I went out and got a 330W Alienware power supply adapter/charger with the proper voltage but more juice. I searched and searched for power supply adapter from its common size to the uncommon size of the charging port on my laptop. I got one from some obscure seller on the Austrailian Ebay.
The result? No more overheating. No more throttling. No more crackling sound. No more anything.
Asus, why would you knowingly provide an underpowered adapter with you gaming laptops? This laptop released at $2500... there is no excuse for me having to by a 100$ charger and adapter to replace the one I have.
Not to mention, my battery quit for good less than a year after buying and was not covered. There goes 125$. I am convinced that the stress on the battery while gaming/charging was bad for that battery.
I expect more from an ROG gaming laptop. Once I got things all fixed ( The monitor was replaced under warranty, so that was good. It had a dead cluster) this laptop works beautifully. This should have been the experience from the start!
https://www.ebay.com.au/itm/112529280619?_trksid=p2060353.m570.l5999&_trkparms=gh1g%3DI112529280619....
https://www.ebay.com.au/itm/7-4mm-5-0mm-to-6-0mm-3-7mm-Converter-Cable-for-ASUS-AC-Adapter-Chargers/...
09-13-2018 09:27 PM
09-17-2018 11:01 AM
09-17-2018 11:54 AM
Niija wrote:
Hi again, i decided to buy the same alienware 330W PSU ( Output 19.5V, 16.9A Input 100-240 V 4.4 A 50-60Hz)
and an adapter for my model ( 5,5mm x 2,5mm i guess... )
Mi current 180W PSU ( Output 19.5V, 9.23A Input 100-240 V 2.34 A 50-60Hz)
Thats specs are safe or can damage my laptop? Thanks a lot
09-20-2018 08:20 AM
FastM wrote:
As long as the Output voltage is the same it is fine.
09-22-2018 12:02 PM
09-22-2018 05:16 PM
11-12-2018 10:03 PM
FULLMETALJACKET7 wrote:
Any performance difference when using the more powerful power supply?
