Memory Interleaving / NUMA Node Setting on 2202 (Zenith Extreme Alpha)
Seda
In the 2202 ZEA firmware, the Memory Interleaving option in the Zen DF options is ignored on the first boot when using a TR1950X. This did not happen on the 2101 firmware.
If the system is turned on cold, the setting is ignored - resulting in a single memory pool/no NUMA control.
If you warm restart the system, the setting is applied as expected.
Although I am using Debian GNU/Linux, this should affect Windows workstation loads as well as that's a firmware-set configuration. I have another ZEA system with a TR2990WX in it; that system is not affected by this.
I've dropped back to 2101 for the time being. Anyone else encountered this? Or is there a process to report bugs in firmware?
0 REPLIES 0
