Rampage V Extreme M.2 Performance Question
Counteragent
Howdy Folks,
After installing my new RAM kit (G.Skill 32GB (4x 8GB) F4-3200C14Q-32GTZR DDR4 3200Mhz Trident Z RGB), I was a little rough on the water loop and caused a leak.
Its all been fixed and I've removed my 3 x Geforce 980s and am waiting on some GeForce RTX 2080 Ti Sea Hawk EK X 11GBs. Waiting for stock to hit the store!!!
So since I've removed 3 video cards the M.2 Slot is now available, and I purchased a Samsung 970 PRO M.2 NVMe SSD 1TB.
I've done a fresh install of Windows, busy getting all the Drivers etc for it now etc...
Is there anything in the BIOS I need to do to ensure the M.2 is operating at its full potential / speed?
Speeds do seem great when copying to it from other SSDs just the BOOT time I thought would have improved more?
Yes the MB is getting old on the tooth I know.
MB: ASUS Rampage V Extreme
CPU: Intel Core i7 5960X Extreme Edition
RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
PSU: Corsair AX1200i Digital ATX Modular
GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
1234;
2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
CASE: Silverstone Temjin TJ11 Black with Window Case
OS: Win7 x64bit
JustinThyme
Download and run crystaldiskmark and post up the results. Other than that just make sure your PCIE is set to max speed an X4 for that slot.*
Thanks for your tips I've downloaded Crystaldiskmark and run 1 test. Results below:
Can you view this?
77740
1234;
OS: Win7 x64bit
