Which slot for my soundcard
Boydie66
Hi I have just got a rog strix z590e motherboard with an i5 11600kf. I am going to populate all m.2 slots with no other storage. I will have my gtx 1080 in the first PCIe x16 slot. Do I put my soundcard in the 3rd PCIe slot? Will this make it 2x8 or will the first slot remain at x16?
xmanrigger
Level 12
I would use slot 3 for sound card. Your gpu should still run at X16. Check nvidia control panel after install to verify X16 on graphics card.
GUTS: ROG Strix Z490-A / i9-10850 / 16GB G.Skill TridentZ Royal 4000mhz / WD Black 1TB M.2 - 2TB Ki...
WATER: EK Velocity Strike - CPU / EK-Quantum Vector - GPU / 2X Alphacool NexXxoS UT60 360 Radiators / XSPC Photon Rez / D5 Pump / DISTILLED WATER + Silver Coil
