Hero X m2_2 stuck in x2 mode.
Hamrdeye
I have an Asus Hero X and 2 nvme drives. I can get m2_1 running in X4 mode fine. m2_2 I cannot get past x2. I have no SATA drives and the drive is 970 PRO.
M2_1
96720
M2_2
96721
I have BIOS sent to x4 on both M2 slots and SATA disabled.
5 REPLIES 5
AS185
Hey there,
Make sure you have also enabled the PCIE mode inside the M2_1 Configuration menu. What else comes to mind is changing the settings PCIe speed within the PCI Express Configuration menu. Let us know what's going on.
Hamrdeye
Thanks for the reply.
I am fairly certain I have done that. I am wondering if it is because I have a card at PCIex 1_1? I cannot find anything in the manual indicating that would affect it. I will report back on the bios settings. To clarify, M2_1 is working fine at x4 mode. The issue is M2_2 seems to only report x2, even with manual setting x4 in BIOS. Again I will double check bios settings.
The transfer mode can be hardset on the device.
Crystal DiskInfo can display this information.
I have 4 nvme drives in my system. One reports that it is 2.0 from the factory.
Highlighting in the attatched Pic shows factory speed | operating speed
96758
Hey guys,
So I've been trying to figure this out but I think you will have to test your PC's without any PCIE_X slots. Try just leaving your graphics unit and testing with the M2 slots installed, then adding each PCIE_X component one by one (if you have any) and testing the computer to see the speeds of the M_2 slots.
Hamrdeye
Thanks, will try these suggestions and report back. Will likely be this weekend as I have been super bust with work. 😞
