03-09-2020 06:14 AM - last edited on 03-05-2024 08:18 PM by ROGBot
03-09-2020 06:40 AM
03-12-2020 07:06 AM
BigJohnny wrote:
PSU fan is for PSU, dont count that into any equation for air flow.
The video card takes air from the case and dumps it in the case.
What are you using for CPU cooling?
Id be more inclined to use them as exhaust as your video card is going to get the majority of its intake from the other side then dump all the hot air into the case. Uining it as intake will probably just cause it to circulate hot air inside the case.
03-12-2020 07:03 PM
03-12-2020 08:31 PM
BigJohnny wrote:
Ome way to find out for sure. try both ways and see what temps you get. My experiance with the GPU on air dumping heat into the case its better to pull that heat out the other side which will force fresh air into the front of the GPU intake.
