05-05-2021 08:00 AM - last edited on 03-05-2024 06:59 PM by ROGBot
05-21-2021 07:13 AM
SirOli wrote:
There are two points that may confuse you.
The 11900k is showing very high CoreVids at overclocking above 5g. CoreVid is not Vcore.
The second point is the big Vdroop of this CPUs at OC. When I set 5,2G allcore @1,4V Vcore with very strong llc (llc7) the real Vcore drops to ~1,3V in CB23.
My Vids are above 1,5V Values but the real Vcore is 0,2V lower.
You can measure this with DMM at the measering points of the board or you can see this in the monitoring of eg. HWMonitor. You have to look at Vcore not at the Vids.
If your real Vcore is above 1,5V thats too high for 24/7.
I guess your real Vcore under heavy load is in the 1,30-1,40V range, wich is no problem at all.
