Hello
I have build where using Fan extension card with connected thermal sensors and Noctua PWN fans. Fan curves configured in BIOS via Qfan section and everything works flawlessly, but when machine go to sleep and wake up after, fan which connected to Fan extension card start spinning louder and as I understand they not controlled with UEFI BIOS anymore and only reboot helps. Fans which is connected to motherboard fan port remains in normal operational state.
Here is small video that showing problem after sleep -*
https://youtu.be/EkliomcFliU***
I don't want to use FanExpert and also can't, because mostly of my time system is used in Linux environment.
BIOS - 2001.
*I need to fill bug report?
