One problem fixed, two new ones appear.
After fixing the USB issue I had with my HTC Vive, the Bluetooth 4.1 seems to not work properly.
Also the Network Controller randomly appeared to be broken. Not sure when this happened.
Bluetooth Driver installed: Version 10.0.0.309 (07-08-2017)
LAN Driver installed: Version 22.6.6.0 (11-09-2017)
Image of the error:
Thanks!
CPU: AMD 1950X @ Stock
GPU: MSI 1080 Ti @ Factory OC
RAM: G-Skill 64GB @ 2800Mhz
MOBO: ASUS Zenith Extreme
PSU: Corsair AX860
EDIT: Bluetooth Driver fixed by simply installing the Bluetooth drivers through Steam... Derp sorry. Network Controller issue persists.
