11-15-2017 05:35 AM - last edited on 03-05-2024 09:42 PM by ROGBot
11-15-2017 07:49 AM
11-15-2017 09:05 AM
Mal3vol3nt wrote:
If your setting up windows on those 6 drives try this (SSD/HHD setup).
F2;
load bios
Advance menu:
Set SATA to RAID
Boot menu:
Set CSM to disable
Set other OS to windows UEFI
*Save***
F2;
load bios again
Advance menu:
Scroll to the very bottom and you will see raidexpert2. Create your raid array then save when your done (dont forget to load raid drivers during windows install).
Pretty sure that’s alll I did to get my setup going.
11-15-2017 12:05 PM
c0febean wrote:
That did the trick. Thanks. But what RAID Drivers do I need to select for Windows 10 Professional 64bit?
11-16-2017 07:28 AM
Ljugtomten wrote:
They are included in the AMD Chipset driver package and can be extracted from there 🙂
11-19-2017 04:58 AM
11-28-2017 08:07 AM
