Installed this a few weeks ago. Installed drivers that are required except for audio stuff which I'm not using. Works well except that it initially would display the q codes in debug mode and then finally go to normal mode in Windows per the manual, but it doesn't do that anymore. The mode indicator worked correctly for several weeks and showed R5E in the string after the q codes, but now it shows ASUS only. I believe the only change was a bios update. ? Ideas? Thanks.
MZ790A Bios 2002, GSkill F5-8000J3848H16GX2-TZRK, 13900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ Optimus block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Samsung 990, Windows 11 Pro
