02-18-2015 09:31 AM - last edited on 03-06-2024 03:24 AM by ROGBot
02-18-2015 09:37 AM
02-18-2015 09:41 AM
Chino wrote:
Confirm that you've connected both the 8 pin and 4 pin power cables. Also check that all your PCIe switches are on.
02-18-2015 09:47 AM
02-18-2015 09:59 AM
02-18-2015 11:44 AM
simfreak101 wrote:
Its normal about the GPU fans. There is actually a warning label on the box about it. "Fans may not spin up at full speed or stop on boot, this is normal and is not indicative of a faulty hardware'
Or something like that.
79 is the compatibility boot options in the BIOS; Chances are your BIOS is hosed; Boot up your computer and let it sit there for 5 mins at code 79; See if it gets past it. Chances are after about 3 mins you will hear a beep (if you have the motherboard speaker plugged in); And it will boot normal.
I had this exact same issue. Came from the factory with a bad copy of the BIOS on it; I had to get a external EEPROM programmer to wipe it and redo the BIOS.
There are whole huge threads about this;
02-18-2015 12:00 PM
02-18-2015 09:49 AM
02-18-2015 10:01 AM
Chino wrote:
1. When removing the CPU, did you examine the CPU socket for any bent or missing pins?
2. Have you tested your GPUs in another system to see if they work?
3. Have you tried using your GPU in the different PCIe lanes?
4. Have you tried swapping PCIe cables?
02-18-2015 10:23 AM
marlin0814 wrote:
1 -- No bent or missing pins, but I'll inspect again.
marlin0814 wrote:
4 -- No, I haven't. Chances that the ones default coming out of the power supply are dead?
