05-30-2021 12:02 PM - last edited 3 weeks ago by ROGBot
05-30-2021 04:50 PM
05-31-2021 10:08 AM
xeromist wrote:
If it can maintain 60c without that fan, that's fine. Modern silicon chips don't even throttle until 80c+ anyway. It does this so the user isn't bothered by fans when they aren't needed.
06-01-2021 10:51 AM
06-02-2021 02:11 PM
xeromist wrote:
It will not harm the chip and that's to be expected if the fan is low or off. Also note that mobile chips do tend to run hotter due to the constrained space so if you've had a desktop PC with even a stock cooler that's often cooler than a notebook. I would only be concerned if you get high idle temps with the fan running. That could indicate a problem with the cooling system.
