X670E gene. Power Button nothing happens
Reb00tas
Hello.
Last night i shut Down my computer and today nothings happens when i Press the power button. I also tried the One on motherboard.
There is light under the Q-code display.
I jumped the psu and its turning on.
Will the motherboard turn on without cpu? (Fans spin and light)
If yes, then i guess my motherboard is dead?
Any suggestions?
Thanks*
Jiaszzz_ROG
Hello, Reb00tas.
In general, it cannot boot without a CPU.
Do you have any Q-LED indicators that are lit?
If so, please refer to [Motherboard] ASUS motherboard troubleshooting via Q-LED indicators and follow the steps to troubleshoot.
>> https://www.asus.com/support/FAQ/1042678/
At the same time, please refer to [Motherboard] Troubleshooting - No Power/No Boot/No Display to troubleshoot problems that cannot be successfully booted,
including trying to clear the CMOS and testing with minimal components, isolating the possible cause.
>> https://www.asus.com/support/FAQ/1042632/
If there is an inoperable part of the process, please let me know which is it.
