10-08-2022 05:53 PM
10-09-2022 11:18 AM
10-10-2022 06:48 AM
10-10-2022 08:12 PM
10-11-2022 05:18 AM
STARRAIN@ROG wrote:
Hi HabaSkeb,
Do you have the mouse issue after wake up the pc from sleep mode and the issue was gone after you reconnect the mouse, but the issue occurs again after wake up the pc from sleep mode?
Is the motherboard in your friends pc also TUF B660-PLUS WIFI D4?
Did you use the mouse only with Armoury Crate installed and firmware updated? or there was no issue before you install Armoury Crate and update firmware when you used the mouse first time?
10-11-2022 06:45 PM
10-12-2022 08:38 PM
STARRAIN@ROG wrote:
Hi HabaSkeb,
May I know which issues persist after disabled the pc sleep?
How often do the issues occur?
May I have the following information?
- the serial number of your mouse via pm
- screenshot of Armoury Crate update center and firmware version
- OS version and OS build
- collect Armoury Crate log when the issues occur and the issues were gone after you reconnect the mouse via pm
In Armoury Crate "Settings"â‘* and check "About"â‘¡ page, If clicking App Diagnostics "Record Log"â‘¢, the Privacy Policy Statement will pop out. Once agreed statement, the Armoury Crate will start to collect problem log and please click "Generate log data"â‘¢ to generate the log file with encrypted (ASUS log file).
- I would appreciate if you could help to record video of issues when collect log
10-13-2022 12:28 AM
10-13-2022 09:36 AM
STARRAIN@ROG wrote:
Hi HabaSkeb,
May I have screenshots of your each mouse profiles?
For Armoury Crate log, could you please help to upload it to google drive or other cloud storage and share me the file link?
(Please set it as everyone can access the file with the link.)
10-13-2022 07:23 PM
