I'm using 5900x with Dark Hero VIII
when gaming, sometimes (quite often) the cpu speed and temps gets stuck and not fluctuating (@hwinfo64) and when i went to check at ryzen master, it couldn't run because it seems like the cpu is missing..
and when i tried to restart the PC, it gets stuck at blackscreen and the mobo then showing 05 code.. only hard reset can do.
How to fix that?
Thanks
