Cannot connect bluetooth to audio devices
Awergamer
When I try to connect a bluetooth speaker, it says connected than paired.But it does not seem to work in any audio devices.I can send files over bluetooth but no audio device is working.Do you have any solutions I tried many things but not worked.
ASUS G752 VS - GAMES THE WITCHER 1-2 GTA 5 SOMA
STARRAIN_ROG
Customer Service Agent
Hi Awergamer,
May I have the bios version?
Did it occur after any update?
Please reinstall Intel BlueTooth driver V19.01.1627.3533 from our support site.
Awergamer
Bios version is 305, I dont remember if it occured after any update.I tried to uninstall all drivers from device manager but did not worked.
STARRAIN_ROG
Hi Awergamer,
If you have tried Intel BlueTooth driver V19.01.1627.3533, please backup your personal files and then reset the system.
Please also restore bios to all default settings.
