First post so bare with me. I looked everywhere but still can't find the answer I am looking for. I have a Asus Vii Gene on the way, and have a quick question about the sound. To use the Optical S/PDIF out do I need to install the sound FX card? I have the Logitech Z5500 speakers so it has an optical input but I am unsure if I need the sound card installed to use it. The reason I ask is I just think the card ruins the "clean" look I am going for, so if I don't need it, I won't install it. Thanks for your help.
FIY Build is:
Asus Vii Gene
Corsair Air 240 case
i7 4790K
16GB Corsair Vengeance Pro 1866Mhz
EVGA GTX970 FTW
Corsair H105
Samsung 256GB 850 Pro SSD
