08-03-2015 09:09 AM - last edited on 03-06-2024 02:19 AM by ROGBot
08-04-2015 07:53 AM
smurf2047h wrote:
Do any of these look unusual for this processor? The thing I don't understand is if I enter these values manually non of them are stable
08-05-2015 04:54 AM
Arne Saknussemm wrote:
You set XMP and then change multi to 44 and set manual voltage 1.375 say...and LLC and Current capability in DIGI+ settings?
Let us have some details of what you set...
Screenshots of BIOS even if you format a USB pen FAT32 and press F12 in BIOS...
08-06-2015 10:00 AM
08-06-2015 12:51 AM
08-07-2015 04:57 AM
08-09-2015 02:37 AM
For the OC I would try CPU current cap at 170 or 180% these CPUs quite often like that up high to be stable and I have it direct from Raja that that high is no problem. I would set LLC at MED. Also disable CPU Spread Spectrum when OCing...make sure the power phases are optimized or extreme...think current cap might set this automatically up high...
One thing..I see VCCSA manual voltage but no voltage set...best return that to auto or if manual input a voltage..
08-08-2015 04:07 PM
smurf2047h wrote:
I'll start by apologising if this is in the wrong section, first time posting here.
Before I get into what is going on can I first ask what is the recommended/common 24/7 voltage of these processors as all the information I'm getting now is starting to get confusing/overwhelming but as I understand 1.4v on water max?
Currently I've tried the optimised defaults and ran for 4 hours p95 blend test. no faults max temp 55c
I've ran auto voltage at current multipliers and this is what I get reported in cpuz :-
4.4 @1.376 max temp 64c
4.3 @ 1.328 max temp 61c
4.2 @ 1.328 max temp 59c
3.9 @ 1.248 max temp 55c
All tested 4 hours P95 blend test
Do any of these look unusual for this processor? The thing I don't understand is if I enter these values manually non of them are stable so unable to lower afterwards. I have also tested the ram separately to rule out ram instability. All ok on auto just unable to set manually
Done the same with ram tested at stock 3.9 settings 1333 no faults. then ran at rated xmp profile 2133 all ok. mem86 8hours each test clear.
These are just some of the many setting I've tried just too many to list. Essentially this is what I've done at a basic starting point
So in a nutshell would somebody please spend a little time with me going through different things to try and achieve a good 24/7 overclock. Primarily I use this for gaming. What I'm really looking for is the best performance from my equipment and I don't feel auto settings are giving me that.
Thanks in advance for any help given
08-09-2015 06:17 AM
08-09-2015 07:37 AM
