The bios size and your screen has to do with the default resolution of your monitor or as I suspect a TV screen.
You can select the DOCP option in BIOS and select the frequency closest to the specified on the sticks of ram. Do not go over the specification unless you are willing to add voltages to the system.
Please do remember that most kits of ram are made for Intel systems and as such the rated speeds are in line with the Intel conventions and may not match the AMD frequency on offer.
