Thx, MeanMachine! 🙂
So... I'll just be going through the list, step by step and look at what I've done and what I can do that I haven't. But I've already gone through most of it a few times now, sadly without the results I was hoping for. :mad:
I have built more computers than I can remember, for at least two full decades, and have been developing, servicing and done mech repairs on everything from computers to high end mobile phones as well, so I just hate being thrown off the horse by something like this. I kinda feel that I should be able to see what is going on here. But I don't. 😉 :confused:
Connector is right where it should be. Might be a lot of headers onboard, but this is not my first build. I pretty much can manage to find a cpu fan header in my sleep. There are two cpu 4-pin connectors on the board. I've tried both, checked the headers for damages, et c. It is all as it should be.
BIOS crashes instantly or within half a minute when entering it. All I can see in BIOS/UEFI is those hysterically crazy numbers going totally heywire in all directions with just milliseconds between 0-28000 rpm and everything inbetween. The sensor does not pick up anything, and is just randomly showering me with numbers. Therefore, there isn't even anything to control. The board doesn't know what to control or look for in the first place. 😕
The random, looping, werid numbers from the fan connector is the same in BIOS as it is in Windows. No difference. Except windows is way more stable than BIOS is. It only freezes up totally once a day, while BIOS crashes as soon as I look at it, basically. And I don't like that. It's something I expect from an old Asrock pile of rubble, but not a Crosshair board. Know what I mean?
The Scythe controller is a mechanical switch with its own physical temp readers on its own cables and also 6-channel fan controller with its own wiring that doesn't ever come into contact with the motherboard connectors. That way, I usually control all chassis fans via physical controls at front panel and I can check manual readings for the entire case, at 6 selected places around the chassis. All, as I said, totally manual from front panel, with no connection to the motherboard, except the main 12V molex power connector. And, as the PSU is totally new, stable as anything and one of the most raved about PSU's on the market (EVGA SuperNova G2), plus the rest of the 12V line of molex connectors work just fine, I don't think there is any problems with that either. Which is a bummer, since it would have been easily fixed, obviously.
Since there is only one motherboard fan header connected at all, which is the cpu fan standard connector at top of board, and it gives me the same random numbers and non-function as the optional cpu fan header, also after replugging it all, it seems there aren't that many culprits to look out for. Choices are pretty slim. But since I get the same random numbers from headers that aren't connected, it looks to be either hardware malfunction or a very large problem within BIOS. I am not sure which, at the moment.
The cpu fan connector is not connected to the Scythe controller, obviously, which is, as I said, physical - not software. And, since I use the Scythe controller for all chassis fans (six of them, carefully placed from front to top to back to produce a standard design air flowthrough, and with clear paths throughout the chassis via extensive cable managing), there are no other motherboard fan headers occupied. Still, some of the - very unoccupied - headers on the motherboard give me the same very weird random numbers that go dead one millisecond, shows anything between zero and heaven above the next - and keeps on going... Even though they aren't connected. A few of the others don't. They just give me the usually expected N/A. So... with me, I sense that there is something really fishy going on in motherboard suburbia.
There are no problems, as far as I can see, with the physical Scythe controller, though. It works just fine. Does its thing. But that doesn't help the CPU fan or its sensors and controllers onboard the motherboard. Controllers work just like they were built for. The temp readers are showing parts of the chassis being around 20-28C and the highest value being below 30C if no load on cpu and just above 40C while under load.
The pins on the processor are totally okay. And I've been meticulous with the thermal paste used. Could be that it still isn't good enough, but I have never yet had any difficulty with adding a perfectly smooth layer of high-end paste on those darlings before. Which makes me kind of wonder.
As I installed the processor onto this new mobo, I was very careful while doing it, but I did replace the thermal paste and so on, since the processor had already been used on a different mobo for a good while previous to this install. I am kind of wondering if this is partly because the new paste hasn't been "burnt in" just yet. Which would be probable, though. Oh, and while installing my entire games listing (a fair amount of games) on several paralell channels, the hard drives are at about 45C after a few hours of constant writing writing writing. Which is pretty good for being under pretty massive load, after all. So temps shouldn't be a factor either. Except that the cpu fan header and some of the cpu fan headers seem to be living in another dimension, or a few, entirely. 😞 Bummer... They aren't even living in Andromeda anymore. ^^
Both 8-pin and 4-pin connectors, plus the 4-pin for extra power to GPU are all definitely seated correctly, too. And the PSU should be way beyond what I need for this hardware configuration, as well. So powering the motherboard in itself shouldn't be a problem. If there isn't a problem within the motherboard itself. Or problems with drivers/BIOS, compatibility with the cooler itself, or such.
I think I've gone through all steps, but it still isn't any of these things, as far as I can see. :confused: 😞
I could reinstall latest BIOS, again, of course. But I ain't sure what the reason is behind it not working its magic to begin with. It seems like those random numbers are trying to tell me that the sensors just ain't able to pick up any life at all, and that they are totally confused about it. Which seems weird, but that's the best I can make out from this.
Sorry for the WOT, TL;DR thing. Just trying to figure things out, and mapping my own comings and goings while at it.
Really thankful for any input on this.
