z370-h build
jabberwock
Hey guys,
I just bought a z370-h and I really love how it looks and its features! I want to buy a cpu cooler but I want to learn if this board has enough clearance since I am using a RAM with high heat sink. I am currently using SPECTRIX D40 DDR4 RGB from Adata. It has a height of 4.73cm and I want to buy MA410P by coolermaster. Can anyone help me confirm if I will get any problems with this cooler? Or any suggestions would also help since I am a novice in building a PC. I am using i5 8400 for my processor.
4 REPLIES 4
Chino
Level 15
Chino wrote:
The Trident Z RGB sticks measure 44 mm. Perhaps yours might fit if you can raise the fan a little.
72291
Oh cool! so that CPU cooler is fine if you adjust the fan? it doesn't give any problems like it might fall or unstable?
Chino
Level 15
I can't confirm it for you because I don't own the heatsink. But the fan looks like it's clipped to the heatsink. So you might be able to raise it. Try contacting CoolerMaster to confirm.
ok cool! thanks! 😛
