Hello,
I have tried searching the forums for information in relation to this issue and have not found any posts that match what I am looking for.
I am currently running an ROG G703GX. The issue that I am seeing is that the wireless connections I make in different locations, regardless of the output of the router, all caps at around the same speed. Between 50 - 90 Mbps. Now I know that sounds like a generous amount, except that the speeds coming into the locations I am connecting at is between 5 - 600 Mbps and my home network which is Fiber 1000 Mbps.
I have removed all software that could potentially throttle my speed. I have adjusted my network settings to allow full duplex speeds of 2.5 Gbps Full Duplex.
I have reinstalled the drivers for the Wifi card (Several times, including removing the old ones first) and made changes through the Command shell. None of these actions have fixed my problem.
Any suggestions to allow me to get full access to my speeds, I would appreciate.
Thank you
