01-21-2020 06:47 PM
01-22-2020 06:37 AM
01-24-2020 10:38 AM
OutSider420 wrote:
Set it to ignore in the bios*
01-24-2020 01:14 PM
01-24-2020 01:28 PM
davemon50 wrote:
The 4-pin connector must be plugged into the CPU Fan connector on the motherboard to avoid the error. Did you? In your whole writeup over 2 posts I could not find that. CPU fan speed listed in your BIOS as N/A indicates to me that you did not. Then the result would be as expected.
The fact that things are getting worse and you are getting high temps and freezes means to me: assuming you have your power connected properly and also the fans are operating at suitable speeds, then you either have a damaged heat pipe or radiator, or you have applied your paste incorrectly. Conduction is conduction, you are either getting it or not based on one or more of the things I just mentioned. If it's electronics then ensure you plugged into the correct location and the fans are being controlled properly.
