05-23-2018 10:39 AM - last edited on 03-06-2024 08:46 PM by ROGBot
05-23-2018 05:13 PM
05-23-2018 07:10 PM
davemon50 wrote:
It's not talked about much on these forums, but I commend you on your selection of the Corsair platinum PSU. I am so pleased with the energy performance and sound (or actually lack thereof) performance of mine that I would buy it again for every build. Great product. I would encourage you to upgrade to W10-Pro because the extra control you get over just updates alone is worth the investment IMO. I can't comment on Ryzen boards unfortunately as I tend towards Intel.
05-23-2018 07:43 PM
davemon50 wrote:
I meant the PSU discussion doesn't come up a whole lot. I recommend the AXi series. 🙂
