Hi everyone. First things first, my cpu used to work cooler before. I have an Asus CH6 mobo and Corsair H80i. The temps were 32-35 C (idle) and 63-65 C (%100 load). I always update the bios when new one comes (a habit comes from the Ram support), so i'm not sure it was all about the new bios. The new temps are 45-50 C (idle) and 74-75 C (%100 load). And i didn't test the cpu on games yet but when using Handbrake the core speed is fixed to 3.1 Ghz (1st pass) and 2.9 Ghz (2nd pass). I tested with aida64 cpu tests, it hit 3.6 Ghz and then tested with aida's stress test again it was 3.0 ghz (max). Is it all about the heat protection or anything else? I checked every hardware on my pc. I periodically clean my case with air-comp. And my drivers are all up2date.
I need help!
