Zenith II Extreme RGB fan extension
MajesticCat
Hello,
I have the Zenith II Extreme, on W10 v2004.
I have 2 problems :
- I use 2 RGB headers on the fan extension card, but I can't control colors and animations (stuck in rainbow mode). I check into Armory Crates and Asus Aura, but softwares not see the headers, i have only "RGB-Header-1" and 2, which must be the header on the motherboard directly.
- I have TForce xtrem ARGB RAM, and when I boot, one stick blink. I must re-apply settings in Armory Crates tho fix it. Same things with the OLED display, I must re-apply the oriention settings every boot.
If somebody can help me, thank you !
MajesticCat
So I try to use the motherboard RGB header directly, and it's work.
So the RGB header on the Fan extension (the "node" card) can just do rainbow mode, you can't control it 😞
