01-03-2020
07:02 PM
- last edited on
03-05-2024
07:09 PM
by
ROGBot
01-04-2020 06:14 AM
01-04-2020 07:58 AM
01-04-2020 10:00 AM
Hivemind wrote:
I think you can figure it out with this.
going with the Dimm.2 you are going through the chipset first then the CPU (probably lower SSD temperature but a slightly more delay (think not even noticeable)
I got 2 SSD under the heat shield but when the chipset fans starts it kinda warms up the ssd to around 50 degrees (still no problem for the ssd anyway) but this way it is directly connected to the PCIe controller inside the CPU.
01-19-2020 02:24 PM
01-22-2020 08:11 AM
02-10-2021 02:32 PM
xOperator wrote:
Wait, so the Dimm.2 Card, right next to the CPU, is routed through the chipset first?
I was thinking that since it was so close to the CPU, that it used PCIE lanes directly from CPU and not chipset.
So which M.2 slots are going to the CPU first? Its hard for me to see that image because of my screen resolution
edit: okay, found the source of the image, good to go
