Updated this Bios version too and i got 6 reeboots during idle on one day.
Some problem with photoshop too...
running TM5 with:
Config Name=Default
Config Author=1usmus_v3
Cores=0
Tests=16
Time (%)=100
Cycles=20
Language=0
Test Sequence=6,12,2,10,5,1,4,3,0,13,9,14,7,8,1,11,15
Gives an error - now is set the CPU SOC voltage higher,
using a 256GB 3600 CL16 Kit with AMD 3970X CPU.
@beastie
you mean the CPU SOC voltage ?
