Zenith Extreme Stock Voltage
Arne_Saknussemm
Level 40
I was looking for some info on stock voltage on the Zenith Extreme
BIOS 0902
I have good cooling so I presume the CPU is kind of free to do it's full boost thing etc. but I am wondering about the voltage it seems happy to supply itself
Is this normal/safe...are the readings accurate...latest HWinfo
71412
gupsterg
All good chap.
At stock this is Precision Boost/Extended Frequency Range in operation. Based on loading/headroom you'll see cores boost and when highest XFR is reached you'll see ~1.5V. The max column sorta gives the wrong picture if you get what I mean. For example the XFR frequency would have bounced across differing cores, so it would seem from that data the CPU as a whole was getting ~1.5V, but it would not have. The average is lower, this "switching" is also way faster than what SW monitoring can relay as well.
Statuscore is neat little app to load selective cores, see clocks and how boost works.
CPU Core Voltage (SVI2 TFN) is comparable to say a measurement via DMM at socket, this reading has a 6.25mV granularity. VCORE read back from ITE IT8665E is a bit pants, that has granularity of 21.8mV. Unfortunately both of these is just one reading and not per core, VID request is per core.
Intel Defector :eek: AMD Rebel
R9 5900X - Custom WC - ASUS Crosshair VII Hero WiFi - Ballistix Sport LT 2x16GB 3800MHz C16 - RX 6800 XT - WD SN770 2TB - 2x 870 EVO 4TB
24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
:eek: CPU Validation 5.198GHz@1.314v with 4.4GHz cache + RAM 2400MHz@1T :eek:
Da Music video
Arne_Saknussemm
Level 40
gupsterg! invaluable reassurance 😉
Sorry, was posting this while you were replying in my thread...but might serve for anyone else with the same question!
I was already watching it after monitoring reset and you are spot on...it is certainly not loading the CPU as a whole like that...it's core by core that gets boosted and that Vid call made...temps/power/current well under control at all times!
gupsterg
NP 🙂 and enjoy your new build! :cool:.
Da Music video
