Zenith Extreme + Enermax Liqtech TR4 360
ApolloX
For those that have the Zenith Extreme and Enermax Liqtech TR4 360...
1) Which header did you plug the pump into? CPU_OPT, W_PUMP+, or other? Seems like the cable is way too short to reach W_PUMP+ but I’m not sure it will run properly in CPU_OPT
2) Can you fit 8 RAM chips? I’ve read reports where on some motherboards, the pump hoses blocked a RAM chip.
12 REPLIES 12
xiixexe wrote:
Is your pump going strong? Mine seems failed. Hose near pump is hot, pump itself is definitely hot. Here's my CPU's idle temp and it has been throttling a lot. Room temp is 77'F
Did it failed ? because I had my first one which failed and amazon sent replacement . I think my 2nd one also failing . or maybe it just not cold as it used to be and I am using more voltage. but with Offset 1.500 and voltage 1.344 I am getting 80 c when testing Aida64 CPU FPU only test.
This does sound like it is not working properly...I'd RMA it...
Mine failed after 5 months. Your idle temps shouldn't be anywhere near that high. Mine were the same when it failed. I went back to a Noctua NH-U14S and idle temps are around 29-31C now.
