Zenith Extreme Beta UEFI 0901
Raja
From Elmor:
Beta BIOS 0901 http://www.mediafire.com/file/8tp9l0...-ASUS-0901.zip
Have not tested this extensively, let me know how it works for you.
- AGESA 1.0.0.4
- Fan fixes from 0012
- UEFI RAID driver updated (and hopefully back on track)
Beta BIOS 0804 https://www.mediafire.com/file/hurdeb58o4mtjq2/ROG-ZENITH-EXTREME-ASUS-0804.zip
* AGESA 1.0.0.3
* Hynix 2DPC patch (POST issues with all slots populated)
* Fan control fixes, including EXT_FAN card
* PCIEX8/X4_4 lane switching tested and works fine, however, I haven't verified the issue on older BIOS
Please note, some boards have older firmware for the onboard OLED/Aura, which can cause some strange issues. Update to the version here. Run the .exe from within Windows.
After applying the update above, you can apply the version here
UEFI build
0801
NOTICE: If you already have a SATA RAID configuration, make a backup of the array before updating to this build, then rebuild it once you have flashed the BIOS.
For more details and instructions regarding the BIOS/RAID driver, please refer to the following
link
Revised memory rules
Fixed CPU temp reporting issue after CMOS clear
Secure Erase string update
UEFI build 0603
Includes Ai suite patch, RAID driver update, and a patch for Inateck 7-port KTU3FR-5O2U to solve POST issues.
UEFI build 9960 based on 0601:
Automatically applies a 2T Command Rate for 2DPC configs when above DDR4-2820.
UEFI build 0601
public release build.
This will be on the support pages soon. Same as the 9910 beta. Please clear CMOS after updating (allow the update to complete fully before doing so!).
For those of you still experiencing memory instability, try setting a 2T Command Rate.
Older beta UEFI:
UEFI beta build 9910
More memory tuning for dual rank configs
UEFI beta build 9906
More DRAM tuning for compatibility/oc
Added CLDO VDDP Voltage under Tweaker's Paradise
Also synchronized hwm CPU temp with monitor
UEFI build 9980
Improves memory overclocking - again.
UEFI build 9964
Improves memory overclocking, and adds 'Ln2 Tune' option to Tweaker's Paradise.
118 REPLIES 118
From Elmor;
Beta BIOS 0901 http://www.mediafire.com/file/8tp9l09l275uta2/ROG-ZENITH-EXTREME-ASUS-0901.zip
- AGESA 1.0.0.4
Source: http://www.overclock.net/t/1636566/asus-rog-zenith-extreme-x399-threadripper-overclocking-support/19...
Hey guys, just wandering if well see any love or beta bios's for the Strix X399 gaming board ?
Sure but not in the Thread for Zenith Extreme Beta UEFI....
Elmor Posted Beta Bios 902....
Compared to 0901:
- AGESA 1.0.0.3
- 1DPC SR M-die fix
- Dropping DRAM channels fixed
http://www.mediafire.com/file/d9xx4ahci1fdafz/ROG-ZENITH-EXTREME-ASUS-0902.zip
thanks but I still remain in 0801.
in 901 hate in cpu fan probeleme after 2 days
OLD
NEW
I am on 901 Best performance for me. Memory @3200mhz stable no freezes
Cpu Fan is not needed here, Watercooler.
Today i wil try my Raid Controller again because of Agesa 1.0.0.4
I also have a watercooler but not like you have:o
meanwhile have BIOS 0902
OLD
NEW
full fan problem as well as incorrect CPU temperature as you can see from the picture below... although I am using an Enermax TR4 with 3x NF-F12 I don't think my CPU is at -79C...
69865
Compared to 0901:
- AGESA 1.0.0.3
- 1DPC SR M-die fix
Just wandering where the love for the strix board you speak of might be ?
Cheers
Cheers
There still trying to get the zenith working
JpArizona
How important is upgrading the bios?
I am on 0503, everything seems to be running fine, just I get stuttering from time to time.
