Zenith Extreme Beta UEFI 0901
Raja
From Elmor:
Beta BIOS 0901 http://www.mediafire.com/file/8tp9l0...-ASUS-0901.zip
Have not tested this extensively, let me know how it works for you.
- AGESA 1.0.0.4
- Fan fixes from 0012
- UEFI RAID driver updated (and hopefully back on track)
Beta BIOS 0804 https://www.mediafire.com/file/hurdeb58o4mtjq2/ROG-ZENITH-EXTREME-ASUS-0804.zip
* AGESA 1.0.0.3
* Hynix 2DPC patch (POST issues with all slots populated)
* Fan control fixes, including EXT_FAN card
* PCIEX8/X4_4 lane switching tested and works fine, however, I haven't verified the issue on older BIOS
Please note, some boards have older firmware for the onboard OLED/Aura, which can cause some strange issues. Update to the version here. Run the .exe from within Windows.
After applying the update above, you can apply the version here
UEFI build
0801
NOTICE: If you already have a SATA RAID configuration, make a backup of the array before updating to this build, then rebuild it once you have flashed the BIOS.
For more details and instructions regarding the BIOS/RAID driver, please refer to the following
link
Revised memory rules
Fixed CPU temp reporting issue after CMOS clear
Secure Erase string update
UEFI build 0603
Includes Ai suite patch, RAID driver update, and a patch for Inateck 7-port KTU3FR-5O2U to solve POST issues.
UEFI build 9960 based on 0601:
Automatically applies a 2T Command Rate for 2DPC configs when above DDR4-2820.
UEFI build 0601
public release build.
This will be on the support pages soon. Same as the 9910 beta. Please clear CMOS after updating (allow the update to complete fully before doing so!).
For those of you still experiencing memory instability, try setting a 2T Command Rate.
Older beta UEFI:
UEFI beta build 9910
More memory tuning for dual rank configs
UEFI beta build 9906
More DRAM tuning for compatibility/oc
Added CLDO VDDP Voltage under Tweaker's Paradise
Also synchronized hwm CPU temp with monitor
UEFI build 9980
Improves memory overclocking - again.
UEFI build 9964
Improves memory overclocking, and adds 'Ln2 Tune' option to Tweaker's Paradise.
118 REPLIES 118
iI cannot reflash the aura / Livedash firmware flash program said is alread done also not working correct!
Mikan02
I think there might be something slightly wrong with some digi+ settings in the UEFI,
like CPU/SOC/DRAM current capability seems to be better on auto.
Setting current capability to max result in memory training fail at an earlier voltage.
Most noticeable is the SOC voltage, it can actually fail on to much and to little.
CPU and DRAM voltage is same, but most noticeable when pushing limits.
It could explain some of the issues some people got.
Another bug: If you disable LED effects on the motherboard for sleep, hibernate states, etc. (second option) the BIOS disables it completely (disables it for on state, first menu option). You have to go back into the BIOS and re-enable it again to get it to take.
Just trying to understand what is happening, maybe I got this wrong.
The instability that starts slightly below 1.2 SOC voltage and slightly above 1.5 DRAM voltage.
Chipset limitation, IMC limitation, needs better memory settings (still learning) or needs
a new AGESA update from AMD?
Edit:
It is only a issue on memory training and not after post.
Raja
0801 is newer. No need to use an older build unless you have issues with 0801 that you didn't experience on 0701.
Thanks for confirming!
Updated to 0801 from 0503, now DRAM light stays on. The computer post and is running without any issues though. I've never had so many problems prior to this board.
OK, i cleared CMOS and the DRAM light and Load VGA BIOS indicators are gone.
Raja
From Elmor:
* AGESA 1.0.0.3
Any reason to try this bios on G.Skill/Samsung ram?
and why is it still on such an old AGESA version?
any improvments on the coldboot issues with this one?
thanks
