Zenith Extreme Alpha Problem with DOCP
akrovatis
I have Threadripper1920X with G-Skill F4-3200C14Q-32GTZRX running in DOCP at 3200 and suddenly one morning couldn't boot at that speed.
I cannot fix it. Does anybody know what to do?
5 REPLIES 5
Robot_Sonic
Level 11
Hey,
This is a sensitive board for overclocking. If DOCP doesn't work then it's possible to overclock the random access memory manually. It takes a lot of knowledge to do this so maybe you might find some help in the Overclocking/Tweaking area of the forum. There are some users out there with this board overclocked so you might want to wait for sometime to reply. I used DRAM Calculator as a guide but nothing was permanent unfortunately. Good luck.
The thing is that it was working for 2 years with no problems.
I think the problem with the post started after an update of Armoury Crate but I am not really sure.
akrovatis wrote:
Hello,
An update to the AC suite wouldn't cause sporadic POST behaviour, so this is a red herring. If you haven't updated the UEFI, then the overclock was probably slightly conditional to begin with.
Check what value the board is applying for VSOC and increase by 20mv.
I mean after these updates.
Thank you. I will try and I will let you know.
akrovatis
I cannot run the ram even in 2933. I have applied Vsoc 1.1 but still nothing.
