X399-E Realtek Audio Console not working
Frank_Kubis
I installed the latest driver for the realtek from asus support page. This did install Realteks Audio console, witch tells me there thats my device is not supported. Is there any way to get this work? I am not able to configure my audio otherwise.
Frank_Kubis
Thanks, but this did not fix my issue at all. Now the audio console tells can not connect to rpc service. I double checked it, dcom, remote procedute call and rpc endpoint mapper services are running.
BissiJoy
You should update the drivers and also the Windows. You can get the Realtek Audio Console from Microsoft Store.
Here is the Realtek Audio Console Complete Guide
I Hope it will work for you.
