11-04-2018
10:11 AM
- last edited on
03-05-2024
06:53 PM
by
ROGBot
11-04-2018 10:49 AM
11-04-2018 12:11 PM
Arne Saknussemm wrote:
Not sure what to make of all that Canuck5252
I mean you can get unlucky with hardware but that's two boards and two CPUs with bad result.
Do they have 2950X compatible BIOS installed....I presume yes.
You definitely don't need to remove the orange sleeve around the CPU so something is wrong there...
Did you make sure you are tightening the screws down evenly and in the correct order to the rated torque?
What PSU do you have and are the 24 pin and both 8pin ATX connectors populated?
When you changed out the board was that RMA and a reconditioned replacement or new board?
11-04-2018 11:39 AM
11-04-2018 12:11 PM
JustinThyme wrote:
Only one slot now?
Sounds like you have had more than your fair share of failures.
Did you try logging a ticket through the support portal? Its slower but usually ends in resolution and you have trail of the correspondence. Just be prepared to be patient. You always get someone that will send an automated response via C&P from the FAQ section that does you no good. After one or two of those it gets escalated.
11-04-2018 12:00 PM
11-04-2018 12:15 PM
HiVizMan wrote:
Hello buddy can you list your full system specs for me, I am particularly interested in the PSU and the connectors. Could you possibly check and see if they are all firmly and correctly seated. Mate sometimes the little silver metal pin things come out of the plastic connectors and cause no end of grief.
Just trying to remove variables at this point as statistically it is nearly zero to have both 2 x CPU and 2 x motherboards being defective. Can happen of course but...
11-04-2018 12:28 PM
Canuck5252 wrote:
Hello all,
I've been having an odd issue with this board and the 2950x.
I first set it all up 2 weeks ago using this board and a 2950x with 2 sets of CMW32GX4M4C3200C14 which is on the QVL for 32 GBs. I did want 64 so I bought two thinking that would be fine.
I set it all up, it booted, installed windows, all ram was detected and everything was well. I left it overnight and into the next day and everything was working as it should be. Later on in the evening, the computer went into a boot loop with error D0. I removed all the RAM and started checking 1 by 1 in the A1 DIMM and it all booted fine. I started populated the DIMMs and the only DIMM that would not allow a boot and cause the D0 was C1. I could put ram into C2 and it would be recongized but not usable. Therefore, I had only 49 gBs working.
I also realized that I needed ram that was on the QVL for 64 gbs and purchased this set instead : CMW64GX4M8Z2933C16
After reading forums I figured it may have been a bad board so i changed out the board and same issue; C1 would not allow a boot. I then thought maybe it was a bad memory controller so got a new CPU and when I put the new CPU in, C1 started to work, but A1 is now the issue.
Regardless if on the QVL or not, I can populate now C1, D1, and B1 with no issue, but as soon as anything goes into the A1, I get error O0.
I've reseated the CPU, checked bent pins, and even removed the orange sleeve that the CPU comes in for better contact. Oddly enough, for the new CPU, I had to remove it as it was giving me a 00 error with that on. I assume there was poor contact between the pins and CPU.
I have called ASUS support and I keep getting the same gentleman who puts me on hold and never comes back so I thought I'd try here. Is it my luck I got two CPUs, both with bad memory controllers?
Any help would be appreciated.
01-31-2019 11:13 PM
Canuck5252 wrote:
Hello all,
10-07-2021 03:39 AM
