The Aquantia 10g driver is for the LAN card. Only needed if you add it.
The Intel driver is the LAN port on the motherboard IO back shield. Most people
either use latest one or the one that Microsoft installs. Both should be ok but ideal is latest one usually.
Try last post in the thread pisymbol mentioned.
https://rog.asus.com/forum/showthread.php?95682-USB-PCIe-Performance-IssuesI normally do not install drivers for my Razer keyboard, but noticed Windows did not want to auto install
Razer drivers like normal after a new clean install Windows and only used default keyboard drivers instead.
Mostly used to Intel so though maybe it was something with AMD.
This thread and the USB/Perforamnce Issues thread made me curios so decided to try what ssuski did.
Managed to update all but one root hub and it seems like it work cause now it found the Razer keyboard
like normal.
On last clean install my Corsair AIO was found like normal. But kinda unsure about my Logitech mouse,
since I install Logitech Gaming Software (no auto start with Windows, only for drivers).
