03-27-2020 04:22 PM - last edited 3 weeks ago by ROGBot
03-28-2020 02:37 PM
03-28-2020 06:36 PM
chemcup wrote:
Usually 00 means bad motherboard or CPU, it is more likely bad motherboard, you need to RMA it. Mostly if the motherboard ok any memory kit will work fine, you may not be able to overclock the RAM but at least it will work at the default.
03-28-2020 06:31 PM
03-28-2020 10:03 PM
Tux-box1 wrote:
I really need to know where to look up these codes, like the one I pictured. "Memory code: 00". Can someone answer that question, at least?
03-29-2020 12:49 PM
chemcup wrote:
That's mean then it is bad cpu. You can find these codes in the motherboard manual
03-29-2020 12:55 PM
03-28-2020 11:54 PM
03-28-2020 11:57 PM
03-29-2020 12:52 PM
