Tpm = error 33
KraZy_SkitZy
Like many I have started to dabble with tpm, so when enabled I get q code 33, when disabled AA. It hasn't caused any issues an passes memory checks, jus bothers my OCD. Any advice or help on getting rid of 33 or why I get that code?
1950x
X399 strix
8x 8gb Kingston 3200mhz
Radeon vii
Windows 10 pro up to date as well as all drivers
4 REPLIES 4
Jesseinsf
What motherboard or Asus PC/laptop do you have? For some, enabling all Virtualization in BIOS features fixes this problem.
Specs are listed in my post. 1950x cpu, x399 strix
Did you enable Virtualization? I think it's called SVM mode. If that doesn't work then reset the BIOS and enable TPM first.
Tried enabling, an did a bios reset an still get error 33 with tpm enabled.
