System/CPU Fan's randomly get pegged to 100%.
Saturn7
After booting the system, system and cpu fans randomly all get pegged to 100% after a couple of hours while the system is idling.
When I go into fan expert, it shows that the fans are all running at max rpm but the dot on the graph is above the setting line and it's showing idle temperatures.
There is nothing I can do in fan expert to get the fans to slow down or stop. I have to restart the system.
Any idea's?
Running UEFI 9960.
I have run the fan calibration software from the BIOS several times.
Each fan header on the MB has matching fans.
0 REPLIES 0
