10-02-2017 03:42 AM - last edited on 03-06-2024 09:30 PM by ROGBot
10-02-2017 01:56 PM
Deran wrote:
Hello,
Another thing is the CPU_Ready/CPU_Status LED.
On both Mainboards it does nothing. Is this LED working for someone?
10-03-2017 02:43 AM
leyabe wrote:
My CPU_READY LED does nothing, like there is no power to it. It just never worked, from day one. My computer boots just fine though, even though the CPU_READY LED never comes on, whether the power is on, off, computer powered off, sleeping or active.
10-03-2017 04:51 PM
Deran wrote:
I can't believe that this is a hardware related issue, because I have 2 boards and 2 CPUs here.
On both boards the LED does nothing. How big is the chance to get 2 boards with the same symptoms?
01-20-2018 05:14 PM
leyabe wrote:
My CPU_READY LED does nothing, like there is no power to it. It just never worked, from day one. My computer boots just fine though, even though the CPU_READY LED never comes on, whether the power is on, off, computer powered off, sleeping or active. Not red, not green, nothing at all.
10-04-2017 06:52 PM
10-05-2017 02:56 AM
10-05-2017 09:37 AM
ramin_rostami wrote:
for thrradripper you need
min 750w power with 2*8 cpu special connector(normal pc have 1*8)
example
coolermaster full mudular 750W
you need E ATX case , bigger than ATX
example
cougar ponzer case
important = 2 single channel ram NOT dual ,,,, 4*dual channel ram NOT quad so you must use real 4 quad channel ram(4 ram in 1 box writen quadchannel on it ) , not 4* dual channell*
in ryzen you must use only *dual channel , never never use 1*single channel ram , your system cant start , even start will give you tiny freeze
example true ram for threadripper
gskill ripjaws4 2800 4*4*
example true ram for ryzen and all other amd
geil evo x 3200 2*8
or
gskill RGB 3200 2*8
BenjaAS wrote:
Guys follow the link about Mem issues
https://community.amd.com/message/2826804#comment-2826804
Please open a ticket to Asus suport and also to AMD...
NO!!!! RAM is RAM! RAM have specifications
