07-24-2021 11:18 PM - last edited on 03-05-2024 06:57 PM by ROGBot
07-25-2021 08:20 AM
presiado85 wrote:
Hello, so i have Sound Blaster X-Fi Titanium HD. my sound would disappear for a moment and come back. some times it repeats over and over and over till i restart. not all the time the sound would be fixed. removing the Dolby digital signal to regular 2.0 sound setting would fix it. but i read on the amd forums the motherboard for all amd pcie from 3 to 4 have problems with creative sound cards. has asus made a beta bios or driver fix for this?
here is a link form creative stating its not their fault.
https://support.creative.com/kb/ShowArticle.aspx?sid=200427&c
07-25-2021 07:52 PM
KraZy_SkitZy wrote:
Which board do you have? Maybe try a different slot. If you have one of the higher end boards, why bother with a sound card? The integrated on the higher end strix and zenith are fantastic. If you want creative specific enhancements, I recommend these modded drivers that unlock many sound features, such as dolby, dts, creative, etc. https://github.com/AlanFinotty/AAFDCHDriverMod/releases
Also maybe try out a modded bios if you are desperate. Also make sure integrated audio is disabled via the bios if you must use a sound card.
07-25-2021 08:40 PM
presiado85 wrote:
399-e
i really dont like the built in audio processing on motherboards. i already had experienced them before. my many year old sound card sounds much better. i had tried different slots still the same thing. i already tried those modded drivers before. they bring out some enhancements but not on par with sound quality.
07-27-2021 04:01 PM
