10-23-2017 08:26 PM - last edited 3 weeks ago by ROGBot
10-24-2017 04:44 PM
10-24-2017 09:46 PM
St4v0 wrote:
When you do the benchmarks can you also look at Samsung magician to verify the connection speed please
10-25-2017 12:08 AM
10-25-2017 11:44 AM
11-28-2017 10:51 AM
capitaltpt wrote:
Good to know you got it working. I discovered in the BIOS that my PCI-4 port was set to 4x as well. When trying to switch to 8x, it seemed to try to reboot several times and then switched back to 4x. I'm thinking it's a bug.
11-28-2017 07:31 PM
10-27-2017 10:31 AM
10-29-2017 01:43 AM
caknuckles wrote:
I have two 960 Pros. One under heatsink and one on DIMM.2
Both run at PCIe x4 in Samsung Magician. I never changed any of the PCIe settings from their default from BIOS 0501 all the to 0801, without issue.
I have issues only when I disable the 'c' something or other, the legacy boot setting. When I disable that, it will not boot to Windows.
11-18-2017 02:35 AM
capitaltpt wrote:
Caknuckles, Can you confirm if you can change PCI-E 4 from 4x to 8x in the BIOS and have it stick?
11-18-2017 06:54 AM
