10-02-2017 05:53 PM - last edited on 03-05-2024 07:39 PM by ROGBot
11-07-2017 06:14 AM
leyabe wrote:
Well, this thread has lost traction, but ASUS, is there any way you would be able to provide an updated driver that remembers the "Amplify level" that the user selects?
Currently this setting reverts to "Extreme" at every reboot.
I don't think this should be very difficult to implement, the mechanism for switching amplify levels is already there, you just need to remember the user selection across reboots, you know, save the setting to the registry or to a local .ini or .cfg file or something... shouldn't be that hard.
10-31-2017 10:51 PM
11-07-2017 06:16 AM
masterac wrote:
Change your power supply, a bad power supply can be the reason, its possible the noise you hear are the cpu, use to happen to me but on a old asus mobo maximus extrem V, then i change the psu and soundcard too.
Still hapen when i play with friend that have old pc, i can hear their cpu over their microphone.
I havent test the onboard sound card of the zenith yet, i use a usb yamaha controler, i will use a jack 3.5 and tell you if i get anything, since i use a 1500w psu that run underload because of its capacity
11-10-2017 06:28 PM
richac wrote:
Its not the psu, its a driver or bios issue. A usb sound card would most likely bypass the problem, but I paid for my board for the sound chip as well, assuming it would work correctly.
11-10-2017 06:40 PM
masterac wrote:
affirming something without any idea on what it could be is a bit odd, it is more likely he didnt buy the psu recently so it could be a bad one or cheap one, the board on the other end is new, ans since he is the only one posting about this its probable that its the psu
bad power delivery can do a lot of noise on sound, thats also why you dont plug your speaker or peripheral audio device on a power strip, but on an individual one ( same go for the pc)
it also why i have an overkill 1500w power delivery for my computer, so its will never be under high load i think i am around 400w right now.
here are multiple post explaining it :
http://forum.corsair.com/v3/showthread.php?t=85166
https://forums.anandtech.com/threads/static-noise-while-using-onboard-sound.1529077/
https://linustechtips.com/main/topic/245585-psu-making-static-noises/
and here is the rest since there is a lot of it
https://www.google.fr/search?num=30&rlz=1C1ASUM_enFR767FR767&ei=3FwGWqKvH8jRkwX4wJDQCA&q=psu+static+...
11-10-2017 08:01 PM
spadizzle wrote:
Brand new PSU here, check my profile. Does it on the Zenith. Crosshair VI had no sound issues with the same PSU.
01-09-2018 07:27 PM
05-19-2020 07:31 AM
05-28-2020 09:57 PM
10-01-2020 02:27 PM
