09-20-2017 05:42 AM - last edited on 03-06-2024 09:11 PM by ROGBot
03-01-2018 01:19 AM
BigJob wrote:
Do you have the graphics cards plugged in? Take those off and use the on board video. This will narrow the problem down further.
03-01-2018 01:25 AM
gupsterg wrote:
Threadripper does not have "onboard video" ....
03-01-2018 07:54 AM
03-01-2018 10:11 AM
Strykewave wrote:
I’m going to go exchange the board today. My concern is what’s the cause of this if I get another board hook it back up and the same thing happens I’d be on the verge of insanity. So any ideas fellas what would cause this? Bad cpu? I tested the power supply it came on powered the fans and water pump just fine. Idk what else it could be.
03-01-2018 11:41 AM
03-02-2018 01:11 AM
Strykewave wrote:
Microcenter swaps the board out the same day and handles the rma on there end . I left it with the tech there it’s gone over my head and I can’t keep throwing money at it. Thanks for the help I will post wha happened for future reference. Thanks guys.
Cory29 wrote:
There is a Bug after 804 that was introduced
If a storage device is plugged into the back I/O ports then the data can not be read even through uefi flashback tool
If the tool is tried to be used the board will brick and only turning the power on and off (unplugged) for 5 min+ will correct the issue
Its basically caused by unclean programming of the UEFI -- after garbage collect I was able to install the new uefi but the USB storage bug still remains
don't know if you have a variant of this bug -- but after I have found the board power button not responding unplugging for 5 min corrects the problem
(not everyone experiences this bug)
03-01-2018 12:23 PM
03-11-2018 07:25 PM
03-12-2018 01:41 AM
Strykewave wrote:
Defective 24 pin connection from manufacturer.
03-11-2018 11:45 PM
Strykewave wrote:
Any update on this? I’m having the same issue. Originally had 1500watt thermaltake toughpower psu on ASRock Taichi board. Computer worked for a month then stopped thought power supply died replaced with seasonic 1300watt prime *still just board d lighting up. Replaced mobo to ASUS Rog zenith X399 after the everything was put back together only the leds on the board would light up power button on the board does nothing please help I’m running out of ideas as to why this thing won’t even turn on .
Strykewave wrote:
This computer worked with Taichi motherboard 1500 watt toughpower was going to reinstall windows and in the middle of getting this pc ready it went off and only the lights on the Taichi board would light up the sand as the new ASUS zenith. I tested the psu and the fan did not come in so I purchased a seasonic 1300 watt prime hoping that was the issue. Nothing. So I’m stuck with just the lights on the board lighting up. The ryzen cpu was set to game mode when was doing the windows refresh. The reason I was reinstalling windows because I felt the comp was running slow and hitchy so I wanted to reinstall to see if it helps bring back the swiftness of this machine.
