09-20-2017 05:42 AM - last edited on 03-06-2024 09:11 PM by ROGBot
11-02-2017 04:06 PM
10-04-2017 07:26 PM
10-05-2017 07:26 AM
10-05-2017 07:32 AM
ramin_rostami wrote:
100% your ram is wrong , not quad channel
important = 2 single channel ram NOT dual ,,,, 4*dual channel ram NOT quad so you must use real 4 quad channel ram(4 ram in 1 box writen quadchannel on it ) , not 4* dual channell*
(in ryzen cpu you must use only 2*dual channel , never never use 1*single channel ram , your system cant start , even start will give you tiny freeze
on threadripper you cant use 4* dual channel or 4*single channel ram !!!!
example true ram for threadripper (4*quad channel only)
gskill ripjaws4 2800 4*4*
example true ram for ryzen and all other amd
geil evo x 3200 2*8
or
gskill RGB trident z 3200 2*8
NOTE=true slot ??? in AMD you must put ram in exact slot , according your motherboard user manual , so before put ram on ramslot see your mobo true ram slot (wrong slot can make system cant start or crash )
in amd ram is very very very sensetive ,but if you use no1 best ram, you never see even 1 freeze,bluescreen or freeze hang in 1 year !!
01-21-2018 04:41 AM
01-21-2018 11:00 PM
01-22-2018 08:35 AM
01-22-2018 08:55 AM
leyabe wrote:
Thanks, so, are you saying that the LED should light up if there's an issue, but not light up if there's no problem?
leyabe wrote:
As opposed to the manual which says it will light up Red if there's a problem and Green if there isn't?
02-27-2018 06:27 PM
02-27-2018 07:08 PM
Strykewave wrote:
Any update on this? I’m having the same issue. Originally had 1500watt thermaltake toughpower psu on ASRock Taichi board. Computer worked for a month then stopped thought power supply died replaced with seasonic 1300watt prime *still just board d lighting up. Replaced mobo to ASUS Rog zenith X399 after the everything was put back together only the leds on the board would light up power button on the board does nothing please help I’m running out of ideas as to why this thing won’t even turn on .
